94 5.0 engine pinging
ok this is my first post so bear with me. i bought a 94 mustang gt this summer and havnt had a single problem with it. i put on a bbk off road h pipe and flowmaster 44's. when under heavy throttle the engine makes an ugly pinging sounds. is there any way to eliminate this? i run only 87 octane fuel because ive read there makes no difference to switch to 93. anybody else have this problem?
you heard alot..lol what you should of heard is they are a waste of money and will solve nothing related to your problem.....do not waste money on a chip all they basically do is change the timing curve and require then you use high test gas, you can advance the timing yourself, but don't touch it until the pinging issue is resolved or it'll only amplify the prob you have
ok ill stay away from them then . i want to buy some 3.73 gears for my mustang. i found some new on ebay for about 150. is there any specefic set i should get or with any 3.73 work? sorry i just dont know too much so im referring to the experts.
