NEW HEADS CAM INTAKE PROBLEMS
Old 09-28-2009, 11:06 PM
JOSHS93
JOSHS93's Avatar
Default NEW HEADS CAM INTAKE PROBLEMS
I HAVE A 93 GT THAT I RECENTLY PUT TWISTED WEDGE HEADS A HOLLEY SYSTEMAX INTAKE AND A TRICK FLOW STAGE ONE CAM IN BUT THIS THING IS DOGGY THE TYMING IS SET AT 12 AND IT ACTS LIKE IT NEEDS MORE FUEL BUT I DUNNO IN A SWAP LIKE THIS SHOULD I HAVE PUT 24 LB INJECTORS AND A CALLIBRATED MASS AIR IN IT DOES RUN AND DRIVE BUT HAS NO THROTTLE RESPONCE PLEASE HELP
JOSHS93 is offline
Old 09-28-2009, 11:08 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
is the cam timing on?? valves adjusted properly??, 19 lbs inj and stock mass air should work
mjr46 is offline
Old 09-29-2009, 08:28 AM
mattkoly
mattkoly's Avatar
Timing in one place or another is usually the issue when people do a HCI swap, it could be cam timing, or the Distributor is 180 out. did you make sure you were on the compression stroke when you set the distributor?
mattkoly is offline
Old 09-29-2009, 05:13 PM
OnyxCobra
OnyxCobra's Avatar
Double check your timing, I double checked mine twice and it was still wrong.
OnyxCobra is offline
Old 09-29-2009, 06:30 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Originally Posted by OnyxCobra
Buwahahahahahahahahahahahahahahahaha
PRO50SC is offline
Old 09-29-2009, 08:34 PM
mjr46
mjr46's Avatar
lol...
mjr46 is offline
Old 09-30-2009, 01:02 PM
Redneck1465
Redneck1465's Avatar
Haha thats funny I need to remember that for later use.
Redneck1465 is offline
djbigskrilla
09-20-2022 01:04 AM
ding56
08-14-2015 02:40 AM
Redneck1465
08-08-2015 10:39 PM
Jacob4589
08-08-2015 11:00 AM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: NEW HEADS CAM INTAKE PROBLEMS
