bogs down when floored...
Old 10-06-2009, 02:42 PM
9165pt0
9165pt0's Avatar
Default bogs down when floored...
i have been fixing diff issues with my car and it seems like once 1 thing is fixed, something else goes out of whack. i finally got it to idle right and got many of the codes to go away. it drives fine when its normal acceleration half the time. the other half it will make popping noises under the hood under acceleration and it seems lke throttle is cuttin in and out, jerking around. also even when it drives good, it wont go anywhere when floored. flooring it feels like im not giving it any throttle at all?
9165pt0 is offline
Old 10-06-2009, 02:49 PM
89stangbanga
89stangbanga's Avatar
By any chance have you changed anything out to do with fuel? I.e. injectors, maf (Mass air flow sensor) throttle body, sampling tube?
89stangbanga is offline
Old 10-06-2009, 04:29 PM
9165pt0
9165pt0's Avatar
yes i have. i just installed 24lb injectors and sample tube, but last week i could floor it and it would go. didnt seem like full power, but it would definately go. now it doesnt even budge.s
iam still getting codes 41 and 91 and the spark plugs were white on th tips, but at idle it smells pig rich and burns your eyes. so im really confused.
9165pt0 is offline
Old 10-06-2009, 05:02 PM
mattdel
mattdel's Avatar
definite MAF problem. send back as defective and try another IMO.
mattdel is offline
Old 10-06-2009, 05:32 PM
9165pt0
9165pt0's Avatar
umm u think it is the maf meter or sensor? because iam using the same sensor
9165pt0 is offline
Old 10-06-2009, 05:33 PM
89stangbanga
That's definitely a possibility. Do youself a favor and grab your stock injectors, get a white piece of paper and tap out the injectors on a flat surface and see if anything comes out of them(tap it out on the opposite side of the pintle cap). i.e black soot or any sediment. Could be that your injectors are clogged. My car used to do the same thing til i changed out the fuel tank and fuel pump and cleaned out my fuel system then it ripped like hell. But it does sound like it could be a maf problem as well.
Old 10-06-2009, 05:35 PM
9165pt0
9165pt0's Avatar
u think the new injectors could be clogged already?
9165pt0 is offline
Old 10-06-2009, 05:39 PM
89stangbanga
Doesn't take very much for them to get clogged. Just tap out your old injectors, if there is nothing in the old ones that means your fuel system should be relatively clean. Which will let you know that's not the issue. Did you buy the maf, injectors, and sampling tube new?
Old 10-06-2009, 05:51 PM
9165pt0
9165pt0's Avatar
yah new mass air meter, injectors, and sample tube. same old maf sensor.
9165pt0 is offline
Old 10-07-2009, 01:50 AM
chickenbutt
chickenbutt's Avatar
i have bigger injectors and t body with a stock mass air and it runs and idles fine..? think that would still cause issues??
chickenbutt is offline
Quick Reply: bogs down when floored...
