Cranking but no start
i have a 92 EFI. i had a charging problem (bad alt and old battery) and my car would only start if i jumped it. so i replaced the alt with a 130amp and a new battery. started up for a few days fine and then it would just crank and not give me spark, so i replaced the coil no spark or start, then replaced the control module on my MSD dizzy, same thing. fuel pump is turning on, new wires and plugs, all fuses good......still no spark. the ignition is fine, i bypassed it like i was hot wiring it and still no start, im lost , so im curious if anyone has insight or had the same problem.
thank you
thank you
