pinging at 10 degrees timing?
Old 10-11-2009, 05:25 PM
9165pt0
9165pt0's Avatar
Default pinging at 10 degrees timing?
hey guys i was told by the smog shop that my timing was only at 7 degrees on my stock 5.0. it runs strong and doesnt ke it lags or anything. so i set it to 10 and it feels way better, but if you get on the throttle at freeway speeds it pings. i thought 10 degrees was the stock base timing?
9165pt0 is offline
Old 10-11-2009, 05:41 PM
AdderMk2
Banned
AdderMk2's Avatar
check to make sure your balancer hasnt spun
AdderMk2 is offline
Old 10-11-2009, 05:50 PM
9165pt0
9165pt0's Avatar
how would i test it?
9165pt0 is offline
Old 10-11-2009, 06:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
roll motor up to tdc and check where mark on balancer is, and if balancer is not spun then it may be carbon build up in the chambers/on top of the pistons and a good seafoam treatment will cure the issue
mjr46 is offline
Old 10-11-2009, 06:05 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
EGR system working?
PRO50SC is offline
Old 10-11-2009, 06:45 PM
lehrskee
lehrskee's Avatar
my 5.0 pinged real bad too under heavy throttle. switched to 93 octance and been fine ever since. what octane are you running?
lehrskee is offline
Old 10-11-2009, 07:19 PM
9165pt0
9165pt0's Avatar
i got a code for my egr valve isnt working properly. also my spark plugs are chalk white. if i seafoam it should i change the plugs? they have about 7000 miles on them
9165pt0 is offline
Old 10-11-2009, 08:11 PM
mjr46
mjr46's Avatar
if seafoam fouls the plkugs out during the treatment then yes but if not don't worry
mjr46 is offline
Old 10-11-2009, 09:33 PM
9165pt0
9165pt0's Avatar
ok ill seafoam it and give an update
9165pt0 is offline
Old 10-12-2009, 08:03 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
That's where I would start
PRO50SC is offline
Quick Reply: pinging at 10 degrees timing?
