Vfast, help me
Old 11-18-2003, 05:08 AM
makarovboy
makarovboy's Avatar
Default Vfast, help me
Since my early morning burnout in the dirt, I've decided to stay off the asphalt with the mustang. We've decided to park momma's '79 corvette at the asphalt part of the road (go to work, shopping, etc.).
What humonguous spool or total lock-up rear end would you recommend for the 5.0, since I've got the urge to ridge run, with some ocassional circle track and rum running?
P.S.: would you recommend that I rebuild my posi track?
Are you in agreement that some folks just don't get it?
makarovboy is offline
Old 11-18-2003, 03:12 PM
Quik
Quik's Avatar
how about a eaton? or a air locker. or for the cheap way just weld you traction lok together so both wheels are as one unit
Quik is offline
Old 11-18-2003, 03:20 PM
vfast
I ♥ Acer
vfast's Avatar
don't use a spool or weld them remember you still have to turn on the ridge...I would rebuild the posi like 50.00..take one or 2 of the best clutches from the old set and inset them in the new but no side by side space them out is using 2..this will tighten it up as close to a spool as you can get and can turn normal just like stock..make sure you use 4oz bottle of the friction modifer
vfast is offline
Old 11-18-2003, 10:18 PM
makarovboy
makarovboy's Avatar
Hey, how bout that. We are in agreement. Maybe I'll even pave my road. Thanks vfast.
Old 11-18-2003, 11:10 PM
gorbs88
gorbs88's Avatar
IS THAT A GOOD METHOD TO TIGHTEN UP THE POSI...PUT IN 2 MORE CLUTCHES?? IWAS TOLD IT WAS GOOD AND BAD...NOT TO SURE WHO TO BELIEVE...MINE IS GETTIN WEAK.. WILL SOMTIMES DO 1 WHEEL PEEL...VFAST PLS LET ME KNOW...
gorbs88 is offline
vfast
01-29-2004 01:14 AM
Quick Reply: Vfast, help me
