gutted resinators
Old 10-14-2009, 04:21 PM
morgan62
morgan62's Avatar
Default gutted resinators
i lost some power i can feel the difference are they any way i can get my back pressure back
morgan62 is offline
Old 10-14-2009, 05:01 PM
lxman1
lxman1's Avatar
You talking about the cat converters?
I would buy a new H-pipe with a pair of high flow converters in it or an Off-road H-pipe.
The hollowed out cats cause too much turbulence and are restrictive.
lxman1 is offline
Old 10-14-2009, 05:11 PM
socalwrench
socalwrench's Avatar
You just lost some low end torque, but gained top end power. Backpressure helps produce torque.
socalwrench is offline
Old 10-15-2009, 10:16 AM
morgan62
morgan62's Avatar
thank alot it seems like it did gain on top end
morgan62 is offline
Old 10-15-2009, 12:35 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
You will still gain from getting an aftermarket hpipe.
projectresto83 is offline
Old 10-15-2009, 08:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
You guys who believe you need to restrict the exhaust and create back pressure to produce torque are RETARDS!!!!, IF you want to get back your lost torque stuff a potato in the tail pipe...lol, read this and edumacate yourselves!!!http://sbftech.com/index.php/topic,20305.15.html
mjr46 is offline
Old 10-16-2009, 01:46 PM
FoxGT
FoxGT's Avatar
Backpressure is a bad thing any way you look at it. What you lost was the scavenging effect caused from the velocity of the exhaust gasses at lower rpm. Changing exhaust tube diameter changes at what rpm the scavenging is most effective. Ideally you want the most scavenging with the least amount of resistance. When you make the pipe diameter bigger you lower the exhaust velocity & the resistance, the problem is slowing the velocity hurts performance. Basically, there is no all range exhaust. Your pipe diameter is chosen based on where you want the most power. Smaller = more low end hp/tq, bigger = more high end hp/tq.
Requires login.
FoxGT is offline
Old 10-16-2009, 02:03 PM
luckythirteen13
luckythirteen13's Avatar
mjr and fox are both correct. look at top fuel cars, 8 straight pipes off the side of the motor, 0 back pressure.
for a more real world example, look at my car. headers feed the turbos, and from there its just straight piping all the way back. the car makes plenty of torque down low and tons of power up top
luckythirteen13 is offline
Old 10-16-2009, 06:26 PM
mjr46
mjr46's Avatar
Originally Posted by FoxGT
Requires login.
I know, everybody here should have an account there to expand their knowledge
mjr46 is offline
Old 10-18-2009, 04:13 AM
FoxGT
FoxGT's Avatar
I never have as much time as I'd like to look around. Thanks for the recommendation, I'll have to check it out sometime.
FoxGT is offline
panic
08-28-2015 02:37 AM
Pacman
01-23-2005 10:30 PM
mk636
11-18-2004 05:50 PM
shane
07-20-2004 01:25 PM
Quick Reply: gutted resinators
