upper control arm bushing not seated?
Old 10-15-2009, 05:24 PM
camaroeater
camaroeater's Avatar
Default upper control arm bushing not seated?
Its the rear control arm bushing that connect TO the rear end. So my question is, how can i get it back in. Do i need to support the rear while i do it or can i just simply loosen that arm and seat the bushing in. I've wanted to fix this for awhile b/c one tire sticks out more.
camaroeater is offline
Old 10-15-2009, 07:07 PM
fordboy5.0
fordboy5.0's Avatar
one tire sticks out more than the other? you might have bigger problems than that i've done three axle swaps all on mustangs and never had that problem you might have to get new control arms, unless your bushings are bad and need replaced.
fordboy5.0 is offline
Old 10-16-2009, 08:40 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
You can use a C-clamp and a couple of sockets if its not seated all the way. Lubed liberally of course.
projectresto83 is offline
Old 10-16-2009, 09:02 AM
93 LX FiveO
93 LX FiveO's Avatar
sounds like the torque box is ripped/bent
93 LX FiveO is offline
Old 10-16-2009, 10:04 AM
camaroeater
I went and took a look at it, nothing appears to be bent, but the bushings on the lower/upper control arms do look deteriorated. Ever since i got the car, the passenger rear tire stuck out a 1/2" more than the other tire. I forgot to mention that both bushings in the rearend are not seated fully, one sticks out half an inch, the other a quarter inch. Thanks for the input guys.
Old 10-16-2009, 10:24 AM
93 LX FiveO
check the spot welds on the axle tube
they are not too strong
Old 10-16-2009, 10:37 AM
camaroeater
If your talking about where the axle is welded to the bracket that the rear shock is bolted to, they look fine. I looked at all the weld spots in that area and all look good.
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: upper control arm bushing not seated?
