Heater does not work well
Old 10-18-2009, 10:48 PM
Twister2gt
Twister2gt's Avatar
Default Heater does not work well
When i first got my 85 the heat worked well. but for some reason over the years it doesnt work anymore. it just blows just enough heat out to unfog the windows and if it its icy out side forget driving it. I dont drive it in the ice but i would like to take it out on the clean and cool days this winter. The things i have done that could have messed this up would, i got rid of the air conditioner equipment i plugged all my lines. IS there a way i can rig this thing up so it will be hot again?
Twister2gt is offline
Old 10-19-2009, 08:23 PM
money_man
money_man's Avatar
does the engine run colder too?
money_man is offline
Old 10-19-2009, 08:38 PM
AdderMk2
Banned
AdderMk2's Avatar
While the car is running at operating temperature, check the status of BOTH of your heater core hoses.
Are BOTH hot?
is ONE hot and ONE cold?
Are BOTH cold?
LUK!
AdderMk2 is offline
Old 01-23-2010, 06:38 PM
Twister2gt
Twister2gt's Avatar
Okay both heat hoses are hot. Ive made sure that the blend door is turned to the heat position by disconnecting the cable and pushing in by and but still the same problem. I did get the heater core replaced awhile back and haven't had good heat since. is there something else that could be wrong like a vaccum line not hooked up that could cause this? My engine temps stay between 185-200.
Old 01-23-2010, 07:25 PM
OnyxCobra
OnyxCobra's Avatar
is it low on coolant?
OnyxCobra is offline
Old 01-23-2010, 07:27 PM
Twister2gt
Twister2gt's Avatar
No man ive checked everything new thermostat. too
Old 01-23-2010, 07:42 PM
Bubba 95SN
Bubba 95SN's Avatar
Try to backflush the heater core. Remove hoses at heater core and take garden hose and flush water through the core the opposite direction of normal flow. Did a friends Ranger last week and the heater started working. Bubba
Bubba 95SN is offline
Old 01-24-2010, 12:38 AM
12oz
12oz's Avatar
does it only give heat when on highway speeds?
maybe your blower motor?
12oz is offline
Old 01-24-2010, 03:02 AM
Jfsram
Jfsram's Avatar
What temperature thermostat are you using?
Jfsram is offline
Old 01-24-2010, 03:40 AM
TTGreenSN95
TTGreenSN95's Avatar
Default this worked for me
I had the same problem
mine had sludge filling the heater core up
this fixed mine.
TTGreenSN95 is offline
Quick Reply: Heater does not work well
