fuel pump issues
fuel pump issues
I have a 90 mustang gt that I recently installed a 155 lph fuel pump on after my old 110 went out.The car did fine for about a month,then the new pump quit working.I called summit where I got it and they sent me a new one,I installed it and it won't work.I replaced the pump hanger assembly because one of the wires was loose,pump still won't run so I replaced the relay on the passenger side fender and the one under the driver seat,pump still won't run.Am I missing something or do I have a bad wire somewhere?I'm stumped any help would be greatly appreciated.
Ok,thanks guys the inertia switch wasn't tripped,I even tripped it myself and reset it,and no the pump doesn't run when you turn the key on I replaced that relay under the seat but haven't check for voltage yet.I guess I'm just gonna start checking for fire from the fuel pump back up through the system,any more advice would be appreciated.
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
