head noise?
Old 10-26-2009, 08:16 PM
chevyguy69
chevyguy69's Avatar
Default head noise?
I can hear some type of clattering coming from my heads on my 87mustang. They are e7 heads. How tight should i torque my valves? Does that torque number stay the same no matter what cam it has in it?
chevyguy69 is offline
Old 10-26-2009, 08:32 PM
nacanitihs
nacanitihs's Avatar
well, you torque the rockers and it should be 20ftlb. but you gotta do them in the right sequence. also make sure ur lifters are still good
this was fun
https://mustangforums.com/forum/5-0l...-we-found.html
nacanitihs is offline
Old 10-26-2009, 08:50 PM
chevyguy69
chevyguy69's Avatar
thanks for the info. ive never messed with fords before. Im use to having to worry about putting flat spots on cams this whole tightning down to 20lbs call it good sounds sweet! Any idea what the sequence is for the valves?
Old 10-26-2009, 10:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
[/url]
there is no sequence for stock pedastal mount rockers on stock e7 heads, just bolt them down
mjr46 is offline
Old 10-26-2009, 10:30 PM
nacanitihs
nacanitihs's Avatar
actually you want to do it when the lifter is all the way down when there is the least pressure from the spring
Old 10-26-2009, 10:41 PM
mjr46
mjr46's Avatar
like I said it does not matter, I can't tell you how many times I've started at the no 1 cyl or the no 4 and just went across the head, believe what you want but your wasting your time with stock pedastals using the methood that is recommended for roller rockers........ it is only critical for roller rocker set ups to make sure the roller is on the base circle to set proper preload.
mjr46 is offline
Old 10-26-2009, 10:55 PM
mattdel
mattdel's Avatar
this ^^
mattdel is offline
Old 10-26-2009, 11:59 PM
93 LX FiveO
93 LX FiveO's Avatar
time to pickup some new heads
i wouldn't waste time with the E7's
93 LX FiveO is offline
Old 10-27-2009, 01:44 PM
johndeeregreen
johndeeregreen's Avatar
i had a buddy that had head noise to and he had the roller rockers on his kind of a knock and when he took it to gainsville they would laugh and tell him that there was something wrong with his motor, and then he would run 11.21's and no one could finger it out, whoops figure, the oil baffle inside the valve covers was being hit by the rollers some slight mod to the valve cover and away went the noise, but man was it hilarious to see. just an idea I would port the e7 if ya keep em but if ya dont and don 't want to spend alot find a set of 351 w heads they are about the same as ported e7's I agree with the tightening that is what I did with mine.runs fine
johndeeregreen is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
KingRando
10-02-2015 08:06 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: head noise?
