Parking lights don't work...Help?
Hey I have a '90 Mustang, all my lights work, the headlights, the brake lights, the turn signals and the emergency lights but something is wrong with the dash lights where the RPM and MPH is and the parking lights in the back. I took it to my mechanic and he told me it was just all wiring so I was wondering if anyone knows if this is an easy job and where the wiring is for this? There's a bunch of wires where my deck is supposed to be since I don't have a deck I can see all of the wires.
Also if this means anything my horn doesn't work and every time I press or hold my horn buttons the inside headlights turn on. I started laughing when I found this out just thought i'd let you guys know if that helps any? Any input would help thanks, I can't drive at night due to this problem
Dreamer- I will find the wiring diagram and try to trace each circuit, thanks for the help.
PRO50SC- Yes I checked all the fuses and no I haven't replaced any bulbs but the brake lights, the reverse, and the turn signals work perfectly so I didn't think I had to replace any bulbs.
No matter what electrical problem your working with.......always check for power at the device first. Then trace out the circuit and narrow down what your problem is. You can chuck parts at it all day and not fix it if you don't take the time to track it down. electrical can get overwhelming sometimes. just split it all up and check each thing in the circuit one at time.
