Help Identify if Traction Lok or not....pics
Old 11-01-2009, 12:09 PM
Signal 20
Signal 20's Avatar
Default Help Identify if Traction Lok or not....pics
I just baught this rear end out of a 90 mustang lx. The guy who sold it to me said it did not have a traction lok but it has 3.73 gears. He said it has a limited slip, however in my limited knowledge of rear end gears it appeared to be a traction lok system. Can you identify it for me?
Signal 20 is offline
Old 11-01-2009, 12:18 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Yes, it is a trac lok rear
PRO50SC is offline
Old 11-01-2009, 01:38 PM
AdderMk2
Banned
AdderMk2's Avatar
I concur!
AdderMk2 is offline
Old 11-01-2009, 02:05 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Yup and look at the pretty ring gear too! Bling Bling!! lol
projectresto83 is offline
Old 11-01-2009, 03:32 PM
lxman1
lxman1's Avatar
Yep, it is probably a Trac-Lok in need of new clutches if it isn't working.
lxman1 is offline
Old 11-01-2009, 04:50 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
when are people gonna learn the terminology of gm vs ford???? trak loc is fords term for a limited slip rear and gm uses limited slip as their terminology for trak loc
mjr46 is offline
Old 11-01-2009, 05:01 PM
lxman1
lxman1's Avatar
Doesn't GM call "limited slip" Posi traction?
lxman1 is offline
Old 11-01-2009, 05:06 PM
mjr46
mjr46's Avatar
they've used both as well has ford used limited slip terminology, in the end all that matters is both wheels hook
mjr46 is offline
Old 11-01-2009, 05:07 PM
lxman1
lxman1's Avatar
Yep. Don't want a one wheel peel
lxman1 is offline
Old 11-01-2009, 06:07 PM
Signal 20
Signal 20's Avatar
thanks for the quick replys, my second question is can I order and use 31 spline moser axels with this set up or will 31 spline axels only work with a 31 spline specific differential?
Quick Reply: Help Identify if Traction Lok or not....pics
