stuck starter
stuck starter
so my starter keeps sticking on i have replaced the starter and solenoid 4 times the nuetral start switch ignition switch and the alternator what else could it possibly be when i go out to start it it just keeps cranking even after the engine has started and when i turn the car off it keeps going and so i disconect the battery i can wait a while and hook it back up and it is still on and sometimes i can reconnect it and it doesnt do anything please help
You replaced the parts already that should have fixed it. My thoughts go back to the ignition switch, which you also replaced. Since the ignition switch is new, look for burnt or damaged wires on that terminal that plugs into the ignition switch. Give it a very good old fashion visual inspection and my educated guess is a wiring intermittent short, not to ground since nothing is blowing. I mean a short between adjacent wires. Good luck, and hope you can get it working.
Larry
Larry
How have the teeth on the last 3 starters you replaced look? Are they chewed up? How does the ring gear look? More wear on one side of teh tooth vs the other?
It sounds like the starters bendix gear is getting hung up on the ring gear from being installed at an improper angle. Are you using any shims on your start to align it.
