82glx low oil pressure(guy says it aint high as it should be)
Old 11-04-2009, 11:20 AM
newpony
newpony's Avatar
Default 82glx low oil pressure(guy says it aint high as it should be)
what can be the issue
is it major??
newpony is offline
Old 11-04-2009, 11:25 AM
AYEOH5.0
AYEOH5.0's Avatar
could be running low on headlight fluid....
need more details!
AYEOH5.0 is offline
Old 11-04-2009, 12:14 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
what psi is it at running at normal temp?
FivePointOhh is offline
Old 11-04-2009, 12:18 PM
Dj_Seph
Dj_Seph's Avatar
I run about 38psi at idle..
Dj_Seph is offline
Old 11-04-2009, 12:26 PM
FivePointOhh
in limbo
hot idle? thats like really high...
Old 11-04-2009, 12:46 PM
Dj_Seph
Dj_Seph's Avatar
Yes. Hot idle. How high should it be at idle? O.o
Dj_Seph is offline
Old 11-04-2009, 01:36 PM
67mustang302
67mustang302's Avatar
What oil weight and pump does it have? Stock pump with like a 10-30 should only be around 10psi at idle hot, heavy oil like 20-50 and it might be at 20psi hot. A high volume pump will create more pressure starting at a lower rpm. Mine idles with 10-30 at around 30psi hot, if you have a HV pump and run 20-50 then I could see it being 40psi at idle hot.
67mustang302 is offline
AYEOH5.0
AYEOH5.0's Avatar
mine idles at 15psi hot no problem. ive heard you really only need 10psi per 1000rpms
AYEOH5.0 is offline
Old 11-04-2009, 02:06 PM
67mustang302
n/a yeah, but blower applications that boost at low rpm(roots/screw, turbo etc) it's advised to run an HV pump to make sure you have enough pressure at lower rpm to deal with the increased load. Otherwise 10psi per 1,000rpm is fine. Flow volume is more important than pressure, in operation the dynamics of a bearing create an oil wedge that can be thousands of psi in a small portion of the bearing, you just need to make sure you have enough volume to continue to feed the wedge. Pressure is an indirect way of measuring flow volume(provided the bearing clearances are good).
Old 11-04-2009, 02:40 PM
newpony
newpony's Avatar
OK THE GUY JUST SAID ONCE CAR IS WARMED UP (IS WHEN THE PROBLEM STOPS)
WHILE DRIVING ITS AT OR AROUND 30(
SAYS WHEN HE COMES TO A STOP SIGHN IT DRODS TO ABOUT 13
BUT FROM READING WHAT YOU GUYS HAVE JUST POSTED THATS NORMAL CORRECT ME IF WRONG
newpony is offline
Quick Reply: 82glx low oil pressure(guy says it aint high as it should be)
