dip stick hell
Old 11-10-2009, 03:25 PM
nitrous_fed_03gt
nitrous_fed_03gt's Avatar
Default dip stick hell
so i go to check the oil on my 88 lx today when the dip stick and tube come completely out of the oil pan. i cant figure out which end goes in the oil pan but even funnier, ive tried putting both ends back in and neither will go. i even beat the tube straight to make it a little easier but still nothing. what the hell is goin on???
nitrous_fed_03gt is offline
Old 11-10-2009, 03:26 PM
mattdel
mattdel's Avatar
take a closer look at the end of the tube and check to see if it actually snapped off flush.
mattdel is offline
Old 11-10-2009, 03:33 PM
nitrous_fed_03gt
one end of the tube looks normal, and the other end has kinda a soda can lip on it???
Old 11-10-2009, 03:45 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Well both ends are nothing a like at all so either it broken or there are other problems here. The end with the flat piece of metal closest to it would be the top where it is supposed to mount to a header bolt. and the bottom where it goes into the oil pan should be pretty distinct.
ryan_89_mustang is offline
Old 11-10-2009, 03:50 PM
tohoopty
tohoopty's Avatar
just an fyi.the dipstick tube goes into the block.
tohoopty is offline
Old 11-10-2009, 04:03 PM
nitrous_fed_03gt
i recently put shorty headers on my car so that explains why its no longer held in place by the header bolt. i took my dipstick and stuck it down in the hold just to make sure nothing was stopping it and in went through just fine. i just dont get it. ive bent the tube many different ways to get a better angle. proably a dumb question but i assume if i drove the car at all or even started it for that matter, that oil would spurt out of the hole?
Old 11-10-2009, 09:13 PM
XPBaller
XPBaller's Avatar
Thats a 5.0 for you..... **** fallin apart.
lol, jk. And the guy up theres right, it goes in the block not the head.... It should slide right in if you get the angle right. I like to put some silicone around the outside of the dipstick tube where it slide into the block, helps hold it on.
XPBaller is offline
Old 11-10-2009, 09:31 PM
93 LX FiveO
93 LX FiveO's Avatar
there should be a small lip about 1" from the end.. this end slides into the block
it doesn't go in far.
make sure the dipstick isn't hitting the crank.
93 LX FiveO is offline
Gene K
10-21-2015 11:37 PM
BeatnikFink
10-01-2015 08:00 PM
wraith777
09-28-2015 10:49 AM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: dip stick hell
