Parts ID and PArts delete questions
Old 11-12-2009, 12:52 PM
stefke
stefke's Avatar
Default Parts ID and PArts delete questions
I have an 5.0 HO out of an '86 Mark 7 that's going in an '70 mustang coupe. Now are there some things i'd like to know.
What are the missing numbers called?
1: EGR
2:
3: Idle thingy?
4: throttle housing
5: throttle cable bracket.
I know i can throw out that EGR, but what about no.2? Can that piece go too?
Second pic:
Overhere, i don't have to pass any emissions, so i don't need it and want to get rid of it. What can go and what must stay on?
stefke is offline
Old 11-12-2009, 01:11 PM
motorman524
MF Informant
motorman524's Avatar
First pic: #3 is idle air control, #2 can be taken care of this with this.. http://rjminjectiontech.com/?p=9
second image this may help:
http://www.allfordmustangs.com/forum...mrouting-2.jpg
motorman524 is offline
Old 11-12-2009, 01:12 PM
motorman524
MF Informant
Here is another
http://www.allfordmustangs.com/forum...er-20hoses.jpg
Old 11-15-2009, 03:22 AM
stefke
stefke's Avatar
Thanks guys, that helps me alot.
So i got another question about the no. 2 on the first picture. The 2 small tubes are connected to the Cooling system, in this case i suspect it's supposed to heat up the cold air in the winter. Can that be plugged of or should it be left alone?
Second:
On de second picture, i can plug off the numbers 2, 3 and 4.
Can i drill out the numbers 2 and 3? cut in some threads etc? Cause i don't want to plug it off with a small hose with an bolt in it, it looks cheap that way.
Thanks,
stefke is offline
Old 11-15-2009, 11:39 AM
lxman1
lxman1's Avatar
#2 in pic one is the EGR spacer. The coolant lines are actually to cool it down from the hot exhaust flowing thru the EGR system.
If you are not going to use the EGR system, then you can block them off.
You can buy vacuum caps for next to nothing at auto-zone to block #2 and 3. You will never seen them on the car anyway, but for a couple of bucks, you can buy a vacuum plug kit. No need to drill and tap.
lxman1 is offline
Old 11-22-2009, 04:39 AM
stefke
stefke's Avatar
I got a different question, which engine oil should i put in? I'm almost ready to drop the engine in, but i want to fill up the oil and circulate it before i put in the distributor. I work in a BMW motorshop, so i can get Castrol Oil for low €. FYI The engine is all stock.
Which is better? 20w50 mineral of should i go with the 10W40 semi-synthetic? Or something else?
I use 20W50 in my '66 289, mainly cause i don't know the exact condition the engine in is. This one runs strong and no has major prblems so far, except a blown headgaskets 8 monhts ago.
thx
stefke is offline
Old 11-22-2009, 07:25 AM
AdderMk2
Banned
AdderMk2's Avatar
5w30 is what it calls for
AdderMk2 is offline
Old 11-22-2009, 11:23 AM
lxman1
lxman1's Avatar
You sure? 86 should be 10W40 like my 88.
lxman1 is offline
Old 11-22-2009, 02:11 PM
AdderMk2
Banned
AdderMk2's Avatar
only not...
AdderMk2 is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Granatelli Sales
01-20-2020 12:34 AM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Parts ID and PArts delete questions
