Help on catalytic converter help!
Old 11-18-2009, 05:16 PM
Mustang1994
Mustang1994's Avatar
Default Help on catalytic converter help!
On my 1994 5.0, I have straight exhaust at the moment. And I wanted to know if I went ahead and added 2 Catalytic Converter that are 2.5 in and out, and work for a 1994 5.0, will it pass inspection, and it won't screw with my normal driving conditions correct? And would it also keep that straight exhaust sound? i dont have the OEM ones to get inspection, I just want it to keep sound, pass inspection, with my budget.
Mustang1994 is offline
Old 11-18-2009, 05:24 PM
mattdel
mattdel's Avatar
cats are always going to muffle the sound, no matter what. depending on your states laws & the particular station you go to, you might get rejected anyway, because these cars come with 4 cats, not 2.
mattdel is offline
Old 11-18-2009, 05:43 PM
OnyxCobra
OnyxCobra's Avatar
i reckon they have 2 pre-cats and 2 cats stock. Idk about where you live but cars as old as ours just have to pass a visual inspection, as long as the cats are there it passes. If your car is hooked up to a sniffer then you might be in trouble with 2 high flow cats, you might not. Really depends on your laws.
Either way though adding any form of cats to your exhaust is going to change the sound.
OnyxCobra is offline
Old 11-18-2009, 05:49 PM
Mustang1994
Sorry I live in Texas.
Old 11-18-2009, 06:27 PM
Mustang1994
So I can't just get 2 high flows, living in texas, and pass the test, and my car wont have driving problems?
Old 11-18-2009, 06:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
iT REALLY DEPENDS ON HOW THE emissions test is run in your state, THEY'LL be some that may say FEDERAL LAW STATES iGNORE THAT HOG WASH IF PRESENTED, just find out what your local/ state requirement is that needs to be satisfied and do it every state is different.
mjr46 is offline
Old 11-18-2009, 07:33 PM
straight6racing
straight6racing's Avatar
i see you live in houston, tx. they will hook your car up to a sniffer. 2 cats may or may not work. not having mufflers shouldnt be a problem though, its just the emissions testing that might bite you in the a**
straight6racing is offline
Old 11-18-2009, 09:02 PM
Mustang1994
Ok, I know it depends on state rules, and like mjr46 said blah blah blah, but I wanted to know when I do get cats should I get something like http://www.jcwhitney.com/jcwhitney/p...901&id=3182396
Or should I get something like http://www.jcwhitney.com/HIGH-CAPACI...2006217;true;0
or am I needing http://www.jcwhitney.com/HIGH-FLOW_C...2009548;true;0
I know it's a lot but I am trying to find the right cats, and again I know it depends on state law just trying to narrow my search, and possibilities.
Old 11-18-2009, 09:32 PM
mjr46
mjr46's Avatar
if you have a tail pipe test, all that matters is about what comes out the pipe, so a set of high flow may lower the emissions to the proper level, If it were mine, I'd look for a set of used take off ones that some one no longer wants, I picked a set up for 40 beans a few years ago, just for those AL GORE DAYS when it is needed..lol
mjr46 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
jerrytubes
10-23-2015 12:11 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Help on catalytic converter help!
