91 lx 5.0 starts and dies!!! pounding head against wall
Old 11-23-2009, 06:46 PM
thomsenski
thomsenski's Avatar
Default 91 lx 5.0 starts and dies!!! pounding head against wall
Im getting frustrated, its a 91 lx with a 5.0 and an automatic starts and runs for about 10 seconds and dies, i loose spark and fuel ive already replace ignition modual and pick up coil, same effect, tried diffrent coil same concern, when it dies it act like the igntion got shut off, checked igntion switch but cant find anything wrong with it, anybody got any ideas, could this be like a ecm relay or something i cant even find one for it?????
thomsenski is offline
Old 11-23-2009, 09:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ARE YOU SURE IT ISN'T DYING DUE TO LACK OF FUEL?? IF not how did you verify such??
mjr46 is offline
Old 11-23-2009, 10:34 PM
AdderMk2
Banned
AdderMk2's Avatar
so it wont stay running even if you keep hitting the throttle?
AdderMk2 is offline
Old 11-24-2009, 12:00 PM
thomsenski
thomsenski's Avatar
i verifed this by sparing carb cleaner into engine and had no effect, i also watched with spark tester and noid light just shuts injectors off and spark dies, touching throttle doesnt effect it i even held engine at over 2 thousand rpms and still just dies, every once in a while befor the enigne completly stops spining will actually catch and start firing again and stay running for an extra 10 seconds
Old 11-24-2009, 04:27 PM
Tempted
Tempted's Avatar
Sounds like some sort of grounding issue to me. Try swapping in a new ECM if you have one available.
Tempted is offline
Old 11-24-2009, 10:35 PM
dreamer1uk
dreamer1uk's Avatar
Hi,
Is the check engine light on? And whats your fuel pressure at before the vehicle dies?
dreamer1uk is offline
djbigskrilla
09-20-2022 01:04 AM
MEISTERSNFB
03-31-2020 07:50 AM
NorthAmericanTuning
11-09-2016 11:44 AM
1st 4 eyed fox
08-24-2015 06:56 PM
jpplaw
08-22-2015 09:29 PM
Quick Reply: 91 lx 5.0 starts and dies!!! pounding head against wall
