replacing enlink bushings
Old 09-15-2009, 07:46 AM
90Mustang_GT
90Mustang_GT's Avatar
Default replacing enlink bushings
i need to replace the endlink bushings. how hard are they to replace? are any special tools needed? and if all goes bad can i drive it to a shop w/o the sway bar and endlinks on?
90Mustang_GT is offline
Old 09-15-2009, 08:49 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Its not hard but alot of the time they can be rusted and not want to come apart. It takes either two 9/16 or two 1/2 inch wrenches. You might want to get the whole endlink kit, not just the bushings. The can be wore down where it bolts to the control arm and break. You will be fine driving without them if you can't do it. Just a little more body roll in the front.
projectresto83 is offline
Old 09-15-2009, 10:01 AM
socalwrench
socalwrench's Avatar
If you can change your oil, you can swap out the endlink bushings.
socalwrench is offline
Old 12-01-2009, 08:25 PM
5.0muscle
5.0muscle's Avatar
Thumbs up
i thought there was more to it than that. good news for this amateur
5.0muscle is offline
Old 12-01-2009, 08:30 PM
mattdel
mattdel's Avatar
having done thousands of these, i'll tell you that you might end up needing cutting tools to get the old ones out.
mattdel is offline
Old 12-01-2009, 09:13 PM
AdderMk2
Banned
AdderMk2's Avatar
+1
when I did mine, I didnt even bother trying to unbolt them.. I just took a sawzall to them.
AdderMk2 is offline
Old 12-01-2009, 09:30 PM
tohoopty
tohoopty's Avatar
i used an impact to take mine off.i usually just tighten them up and break them off.
tohoopty is offline
Old 12-01-2009, 10:07 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Hmm. Mine just unbolted fine. Thank god for a southern car. Ive not come across one rusted bolt on that car (havent messed with the water pump though).
Boss_Hotrod is offline
mtgldr
02-03-2024 09:00 PM
5.0muscle
01-11-2016 01:17 PM
9550
10-26-2015 05:01 PM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
Quick Reply: replacing enlink bushings
