heatsoaked fuel pump?
start with the fuel filter, sediment may be built up.
the regulator is hardly ever at fault, if symptoms persist, the fuel pump MAY NOT BE TOAST, but the internal clamps and rubber line that is inside the gas tank on the pump itself loves to develop leaks from a broken clamp or hole in the line itself.
well, while my car was warmed up and sitting there, i popped the hood and noticed the fuel pressure was at 10psi! then it slowly dipped to 5 and then the car shut off. im changing the pump
new fuel pump is in. on start up i had 30 psi and 40 w/ the vac line off. better numbers than 20psi or less! and prior to that, having the vac line off or on, the psi was still the same. car runs much better now.
mrappe
09-26-2015 10:16 AM
