12v switched
Old 12-10-2009, 10:58 PM
flight86
flight86's Avatar
Default 12v switched
I will be installing an electric fan this weekend, and was wondering were would be the best place to get the 12 v switched?
flight86 is offline
Old 12-10-2009, 11:42 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
What electric fan did you get? Are you asking where to find a 12v key on power source? Are you going to be using a toggle switch to run the fan or do you have a controller?
projectresto83 is offline
Old 12-11-2009, 08:35 AM
flight86
flight86's Avatar
Yes... I was asking where to find a 12v key on power source. I will be running a Taurus fan with a DCC controler FK50P.
flight86 is offline
Old 12-11-2009, 09:31 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
some of the wire that go through the fire wall are switch 12 v, I usually buy a tap a fuse spade and tap off a switched circuit on the fuse box
mjr46 is offline
projectresto83
M.A.D. Motorsports
The canister purge solenoid is a good key on 12v source. Located around the passenger frame rail by the charcoal canister in the front of the engine bay.
Old 12-11-2009, 05:32 PM
AdderMk2
Banned
AdderMk2's Avatar
I hope you did the 3g alt conversion
AdderMk2 is offline
Old 12-11-2009, 11:10 PM
projectresto83
M.A.D. Motorsports
^^If you haven't yet at least better be your next upgrade. If you are wondering why its because the stock 75 amp alt on the fox sucks and when the fan is running it sucks up almost half of what the alt produces. Its not going to kill you instantly but you will notice you headlights will be alot dimmer than what they already are.
Old 12-12-2009, 12:15 AM
flight86
flight86's Avatar
Yeah..I upgraded to a 3g alternator about 3 years ago.
flight86 is offline
Old 12-14-2009, 03:54 PM
Jfsram
Jfsram's Avatar
If you run a non switched source. It will allow the fan to continue running when you shut a super hot car off.
Jfsram is offline
Old 12-14-2009, 05:48 PM
smkmup90
smkmup90's Avatar
Where do you get the DCC controllers from?
smkmup90 is offline
Quick Reply: 12v switched
