budget build 302 to 347 stroker
i myself am slowwwwly putting together my plans for my engine...
i'm planning to do a 331, NOT a 347... what research i've done says that stroking to 347 leaves such short pistons that you compromise the o-rings and the integrity of the piston head... 302->347 stroker is short-lived compared to a 302->331. anyone who has information to the contrary please correct me.
from what i've found out so far, it looks like it's going to cost me $4k-$5k to build an engine myself, slowly and meticulously, in my garage.
my first stop is going to be 3.73's, a new trak-lok, and 31-spline axles in the spring.
then a tko-600 trans... chassis reinforcements... ultimately engine build.
do it slow and do it right .
see if you come back with your head
there is absolutely no difference in reliability or life span when comparing a 331 to a 347. the things you found must be from years ago, when that used to ahve some truth to it.
and to the o.p.
i agree with other people. don't touch the lower end until you have more money. I'd swap the h/c/i out for some nice used aluminum heads, get your decent sized cam, and an intake and other miscellanious pieces. fing it all used for good prices you can keep it to 2 grand and still come out with about 300 whp.
and to the o.p.
go ahead make less power with a 331.. one more mustang on the road for me to wax..!
1. One of the 347 stroker configs (3.4" stroke and 5.315" rod), if piston comp height is that crucial to you, uses the same piston the 331 stroker setup uses. So how could the piston be "short" for a 347 and not for a 331?
2. 347 stroker longevity misinformation is not due to the setup, it is due to bad engine building practices.
Allow me then......... that is simple information. Why?.....
2) This is exactly why I'm not starting on mine yet - the more I know before I start blowing money on components, the better. I'm planning for this to be a slow, careful and meticulous process.
I love the info I get on these forums.
FYI....... here's a 331/347 short rod piston. Look at the crown and top of ring land. 1.175" Compression Height, .195" Deck Thickness
Here's the 347 long rod piston 1.090" comp. height, .225" deck thickness.
Again... the "integrity" of the piston is not compromised, they are set a little different...... that's all. Shortening of the piston compression height is to keep everything within the deck height boundary, not for valve clearance problems.
www.propowerparts.com sells a 331 stroker kit for$775. You can get a set of pro comp 190cc aluminum heads on ebay for around $600 new and I would go with a Comp Extreme energy 274 hydraulic roller cam (.555/.565 lift). $249 at summit racing. Muscle Mustangs and Fast Fords magazine did an article on the pro power 331 stroker kit and it installed with no block clearancing needed. Hop this helps.
