budget build 302 to 347 stroker
i want to stroke my 302 to 347 from a 90 mustang workn on a budget of around 2000 wat are some good recomemded stoker kits .also want to have a big cam on it.been thinking about the chp kits
dont bother stroking the motor if you arent prepared to buy a 185-190cc aluminum head. stock heads ported or not are a joke on a 302 let alone a 347. you can get some used afr's for about $1000-1300. factor that into your budget
i myself am slowwwwly putting together my plans for my engine...
i'm planning to do a 331, NOT a 347... what research i've done says that stroking to 347 leaves such short pistons that you compromise the o-rings and the integrity of the piston head... 302->347 stroker is short-lived compared to a 302->331. anyone who has information to the contrary please correct me.
from what i've found out so far, it looks like it's going to cost me $4k-$5k to build an engine myself, slowly and meticulously, in my garage.
my first stop is going to be 3.73's, a new trak-lok, and 31-spline axles in the spring.
then a tko-600 trans... chassis reinforcements... ultimately engine build.
do it slow and do it right .
