Cam Question
Old 12-14-2009, 12:00 AM
sgarrelts01
sgarrelts01's Avatar
Default Cam Question
Since i am going to a Carb set up, what about the cam. I see on CompCam website they have Carb Roller cams and EFI. What is the difference.
Is their select few cams i can use. What would happen if i put a EFI cam in a carb set up.
I don't want to do custom right now. But i was a cam with a very aggressive idle that will help me get to 350-400hp at the rear wheels.
Also a question about the Ford Cams,
What ford cam packs the most power and aggressive idle
If the cams go in order wouldn't the X or Z cam be the biggest
Are they capable of being used with a carb set up.
sgarrelts01 is offline
Old 12-14-2009, 06:37 AM
Joel5.0
Joel5.0's Avatar
Cam selection or the design of a cam (if you choose custom), requires a lot more detailed information than the type of induction you will use or idle sound characteristics ..... specially with those aggressive HP goals at the wheels... + the alphabet cams will not support your performance goals.
Joel5.0 is offline
Old 12-14-2009, 07:53 AM
sgarrelts01
whats a good roller carb cam that has the potential to get me to 400hp.
with AFR 185
331 stroker
Eddy Rpm air gap with a holley 750
Old 12-14-2009, 09:30 AM
Joel5.0
Joel5.0's Avatar
Replace that intake for a good old Victor Jr. add the correct valve train based on the cam profile, and a custom cam will take your setup there. Just like the real life 331 sample case.
Right at peak HP for ~700-800 RPM and above 300 ft-lbs of torque for a 4100 RPM span after ~2600 RPM.
Joel5.0 is offline
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Cam Question
