cooling fan wiring question.....
Old 12-21-2009, 03:03 PM
ShortBusKustomz
ShortBusKustomz's Avatar
Default cooling fan wiring question.....
I just got my 88 Stang GT, and it already had an aluminum radiator with a new set of dual cooling fans and they were already wired up. Problem is the way that had it wired up was causing my ignition switch to go out over night every time i replaced it with a new ig switch. My question is this.....where is the best place to hook the yellow wire up to a 12v switched source to where i am not replacing ignition switches everyday????? any help is appreciated, and i am sorry if this has been posted already, but i didnt see anything when i did a search on the website here!!
ShortBusKustomz is offline
Old 12-21-2009, 03:22 PM
mattdel
mattdel's Avatar
to the switched side of the solenoid would be the best option, with an inline fuse. if its blowing ignition switches while the car is off, its wired wrong.
mattdel is offline
Old 12-21-2009, 06:13 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Is a relay wired in as well? That will also help protect w/e circuit you have it wired in to.
PRO50SC is offline
Old 12-22-2009, 06:28 AM
ShortBusKustomz
yeah it has a relay wired in, matter of fact the wire in question comes off the relay for the fans....
Old 12-22-2009, 05:01 PM
steel1
steel1's Avatar
I wired mine using the same controller in this post, but a 95 Merc. villager fan. It has some good general info, that could be applied to any elec. fan install.
http://forums.corral.net/forums/show...ight=flexalite
steel1 is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
PaulH2
20
01-31-2016 09:48 AM
Dathan
10-05-2015 05:52 AM
09-25-2015 09:06 AM
Quick Reply: cooling fan wiring question.....
