Stock 94' 302
Stock 94' 302
I have a 1994 Stock Mustang GT and it has no compression on one cylinder. The engine is fixing to be torn apart and redone, and before I start rebuilding I would like to know what size Cam the stock 94 Gt come with, and what Cam would be best to replace this with (For Low End Torque). I may also replace the Manifold with a Trickflow, and if I do that I will possibly need bigger headers.
RE: Stock 94' 302
If you want a cam for regular street driving I would get the E303. My mechanic said the E303 works fine in a stock motor, and will not bring down the longevity of the motor very much. If you want a aggresive/racing cam that would be the X303 but, you would have to replace you heads along with several other components. However, the X303 doesnt really kick in till higher rpms.
RE: Stock 94' 302
Hello I was reading your post, don't go any fms cams, go with the comp cams made for the obd 1 computer, the other cams have to little lobe sep, and you will have nightmares trying to idle that thing,,, comp make two cams for us 94-95 owners,,, only those twowill work or the computer will hate you with anything else in there aftermarket....
Galactic
04-29-2019 02:56 PM
jaiidutch
09-14-2015 10:29 AM
