what times should i run with t
Old 11-20-2003, 02:00 PM
347 and sprayed
347 and sprayed's Avatar
Default what times should i run with t
i have a 347 with TFS Heads,Edelbrock intake,1.6 rockers,E303 cam, 65 mm throttle body, 75 mm mass meter,pulleys,forged pistons,complete bottom end,3.73 gears,mac H-pipe 2-chamber flowmaster with mac 1 5/8 headers,150 shot nos,with a 190 lph in tank pump also a inline pro charger pump24 pound injectors with a ram power grip clutch
347 and sprayed is offline
Old 11-20-2003, 03:04 PM
Quik
Quik's Avatar
if you dont hit high 11s id sell the car and buy a geo.
your setup looks good but you have a stroker with steep gears youll burn them off way to quick and top out a little early. with a stroker a 355 would be better since you wouldnt be spinning the motor so quickly and actually using the whole power from the motor. gears are great on a under powered car but once you get some serious torque then less gear is better.i was planning on doing a 347 single turbo setup runing 308s with a auto.[for example]
but with out a good suspension and tires you anit going no where
Quik is offline
djbigskrilla
09-20-2022 01:04 AM
YoungStangsMan
09-05-2015 07:01 PM
gus_vb
08-29-2015 11:35 PM
1987gt40ttopt
08-28-2015 10:49 PM
timeformiller44
08-26-2015 12:03 PM
Quick Reply: what times should i run with t
