every time i press on the brakes, the tail lights don't indicate im stopping. every light bulb works, i've checked the fuses, grounds and the brake switch. any suggestions?
i know the bulbs are good because the emergency lights work and the lights when the headlights are on and when i put the car in reverse. it's just when i step on the brake, the lights don't indicate so, same with my third brake light.
There is a seperate filament for the brake lights, it is totally possible that they are all dead at the same time. do not presume they are good without looking at them.
its under the dash on the brake pedal, mine died on me. take it out spray it with wd40 and work it in and out for a couple minutes bring it back to life. haha
Originally Posted by PRO50SC
No, each bulb is independent. How do you know the b/l switch is good? Do you have power in and power out of it?
Originally Posted by 19stang88
where is the brake light switch and how can i test it?
If you already tested it, why don't you know where it is??
actually the real problem was that the lady at the part store gave me the wrong part. Thanks for the help. Now my third brake light is not working.
And what part would that be?
Thanks for wasting my time. In the future, don't tell us you've checked something when you haven't!! DEf won't be helping you in the future!!
LOSER!!!
