is stock cam good....but what about the E303
Old 07-23-2005, 05:18 PM
90Mustangfan
I ♥ Acer
90Mustangfan's Avatar
Default is stock cam good....but what about the E303
Ok if I have a 89' 5.0 with heads and intake, full exhaust, stock crank and stock cam...how much HP would I gain from putting in a E303 cam. I have trick flow twisted wedge heads, and pro products intake manifold, mac headers, off road x, and flows.70mm tb,CAI etc... Or is the stock cam good enough? or am I loosing lots of pontential with the stocker cam.how much gain will I get from adding the e303 with heads and intake?
90Mustangfan is offline
Old 07-23-2005, 05:55 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: is stock cam good....but what about the E303
adding 1.7 rockers will help will put your lift around .472
vfast is offline
Old 07-23-2005, 06:00 PM
90Mustangfan
I ♥ Acer
it already has 1.6 roller roker, I saying how much hp will I gain by adding e303, if I already have heads and intake....or how much Hp will I loose by having the stock cam?
Old 07-23-2005, 06:12 PM
dc_mann8
dc_mann8's Avatar
id say 20ish?
dc_mann8 is offline
Old 07-23-2005, 06:24 PM
horatio102
horatio102's Avatar
1.7 rockers will help without changing the cam. With the 1.7 rockers, stock cam, afr 165 heads, and a demon carb + 4bbl intake manifold Car Craft got about 325hp at the crank. Add up the costs between popping the valve covers off and swapping rockers versus pulling the valve covers, rockers, intake manifold, water pump, etc. out and replacing all those gaskets to swap the cam. How much is that little bit of HP worth if you're not an all-out racer? Save the cam swap for when it's time to rebuild or if you ever have to replace the water pump, for example.
ORIGINAL: 90Mustangfan
horatio102 is offline
Old 07-23-2005, 11:05 PM
33boggers
33boggers's Avatar
I am in the middle of haveing an e 303 cam put in with alot of outher things.read here Ihave herd anouther car with the cam and IT SOUNDS SWEET for me the sound is part of the reward
33boggers is offline
Old 07-23-2005, 11:52 PM
Albizo66
Albizo66's Avatar
Oh boggers..i's all about the sound my man...I had the E, loved the sound..had to go bigger and get more sound though..
Albizo66 is offline
Old 07-24-2005, 11:40 AM
vfast
I ♥ Acer
vfast's Avatar
sound isn't everthing...I see tons of nice sounding cars on the trailer as the driver is crying all the way home because he just got spanked by a faster car that sound stock with no lope
vfast is offline
uberstang1
09-20-2015 06:42 PM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
dunebuggydude11
09-13-2015 03:03 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: is stock cam good....but what about the E303
