wiring ??
Old 01-22-2010, 10:34 PM
pgw inc
pgw inc's Avatar
Default wiring ??
switchin from efi to carb for time being im gonna use a stk dizzy and coil anyone kno how i wire this in (i kno i need to make sure the i have bronze gear ) do i need some type of brian box for dist ..... the car is a 91 lx if that helps
thanx
pgw inc is offline
Old 01-22-2010, 10:51 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
duraspark II box is what you need, autozone will have all your needs and it's a steel gear that I'd rather use
mjr46 is offline
Old 01-22-2010, 11:08 PM
pgw inc
pgw inc's Avatar
ur always right on top of thing man thanks
are they pretty st8 forwward as to how to wire them .........and also i really dont alot of wiring coming out both sides of the fire wall since i will usin a different brain box/dura spark 2 box
pgw inc is offline
Old 01-22-2010, 11:20 PM
mjr46
mjr46's Avatar
when you get the stuff pm me, I've wire tons of them up, = easy
mjr46 is offline
Old 01-23-2010, 12:14 AM
pgw inc
pgw inc's Avatar
i will indeed ought thiscar in peices she clean but .............alot of werk ahead of me thank for help
pgw inc is offline
Old 01-23-2010, 12:23 AM
pgw inc
pgw inc's Avatar
one more ? can i use thee in tank (stock location) fuel pump and just use a external fuel pump to the carb set up i have or will that burn up that pump
pgw inc is offline
Old 10-23-2011, 02:18 AM
fast86stang
fast86stang's Avatar
hey bro sorry but i was wonderin if yall can answer my ? i have an 86 that was converted to carb and was still useing the tfi distribter well it worked fine for about a year and then all on a sudden lost spark so i jus changed out the distributer with a carb one wit pretronix and has a red wire and a blk wire i also got a msd blaster 2 coil and still no spark can u tell me whats wrong u can email me at faststang25@gmail.com
fast86stang is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: wiring ??
