TFS Stage 1, 1.6 or 1.7
Old 01-26-2010, 09:36 PM
JayBanion
JayBanion's Avatar
Default TFS Stage 1, 1.6 or 1.7
I posted a little while ago about this but with two cams that were too much for my heads. So I ordered the TFS cam, now should I go with 1.6's or 1.7 roller rockers. Or should I keep my stockers, but I doubt that.
Jay
JayBanion is offline
Old 01-26-2010, 09:50 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
1.6 rockers
mjr46 is offline
Old 01-26-2010, 10:07 PM
JayBanion
JayBanion's Avatar
Thank You Sir
Old 01-27-2010, 06:04 PM
xxxmustangtxhc
xxxmustangtxhc's Avatar
why dont u try 1.6 and 1.7..... 1.6 on the intake and 1.7 on the exhuast side.... just a thought? my first set up made 305 rwhp with 69' D0oE heads TFS 1, 1.6 & 1.7 mix matched and a cobra intake.... just my opinion...i still have rocker set up like i did before and works great..
ps dont mind the gold tooth
xxxmustangtxhc is offline
Old 01-27-2010, 07:43 PM
JayBanion
JayBanion's Avatar
Im just worried about PTV contact. Plus GT40P's only flow good till around .500 lift. And the TFS cam is at like .490/.510 already (something like that).
Old 01-27-2010, 08:27 PM
Bubba 95SN
Bubba 95SN's Avatar
Friends garage had young Marine that was pulling Trick Flow heads off his 332 with stage 2 cam and 1.7 rockers last week. Yup 8 bent exhaust valves. Anyone gets the urge for that I seen what happens. It ain't pretty. He didn't ask anyone just tried.
Bubba 95SN is offline
Old 01-27-2010, 10:09 PM
JayBanion
JayBanion's Avatar
Sounds like the time when I had the timing off on my old 4.6 out of my 98. Never rotated it by hand, except I did worse then bend a few valves. I snapped them off, as well as the cam followers, and put a few nice dents a couple of pistons.
Old 01-27-2010, 10:11 PM
tinman
tinman's Avatar
Always,always check piston to valve clearance anytime you are changing any valve-train parts.
Keep at least .100" of clearance and you'll be fine.
Lift of the camshaft has very little to do with p?v clearnace anyway.......
tinman is offline
Old 01-27-2010, 10:15 PM
AdderMk2
Banned
AdderMk2's Avatar
ok... answer this..
if you buy a cam with .510 lift... and P heads flow crap over .500... how long do you think the valve is running over .500 lift?
seems to me like, you would want the car to be at or around its peak flow potential, for as long as possible...
AdderMk2 is offline
Old 01-27-2010, 11:23 PM
mjr46
mjr46's Avatar
lift has nothing to do with ptv issues which is essentially what a 1.7 rocker does, your buddy had a mismatch , most strokers if built right for use with tfs heads often run the companion piston for such with the rotated valve reliefs to match the rotated valved head..........if ptv occured it may have been a result of radial ptv, a picture of the piston and valves/damage can determine the root cause as well as an over rev / valve float could of casued damage.
mjr46 is offline
Quick Reply: TFS Stage 1, 1.6 or 1.7
