Smog removal
Old 01-29-2010, 05:17 PM
AdderMk2
Banned
AdderMk2's Avatar
Originally Posted by 5.0stang123
K I think im just gonna leave the egr but remove the pump. So the only thing I have to buy beseides a belt is the bolt to plug the heads? Does anyone know exactly what it is I keep getting mixed sizes?
the thermactor ports in the back of the heads are 5/8-11 try to get some that are 1" long, and use a thick washer or two. make sure you apply red RTV to the threads.
you will likely have to clean the ports out, as they get VERY caked with carbon
AdderMk2 is offline
Old 01-29-2010, 05:23 PM
goathead75
goathead75's Avatar
84.5" belt if you're running PS and AC: http://www.cjponyparts.com/tech-fox-body-belts/a/175/
goathead75 is offline
Old 01-29-2010, 07:05 PM
5.0stang123
5.0stang123's Avatar
Ya no Ac^ Adder thanks man, whats a good way to clean back there not alot of room and I cant even see the threads. How thick of washers?
5.0stang123 is offline
Old 01-29-2010, 08:14 PM
Boss_Hotrod
Boss_Hotrod's Avatar
One other thing I didnt see mentioned is: If you unhook the vac line to the egr valve the pcm will automatically delete its function. Just leave the valve and sensor on the intake and hooked up.
Boss_Hotrod is offline
Old 01-29-2010, 08:21 PM
5.0stang123
K cool so plug the vacuum line to egr, remove tubing to heads and plug with 5/8 bolt and washer with loctite then some how plug exhaust? Anything else im forgetting ?
Old 01-29-2010, 08:35 PM
AdderMk2
Banned
AdderMk2's Avatar
no... a 5/8-11 bolt, a washer, and red RTV silicone... not loctite
AdderMk2 is offline
Old 01-30-2010, 06:41 AM
goathead75
goathead75's Avatar
73" then.
Old 01-30-2010, 08:46 PM
Jfsram
Jfsram's Avatar
Originally Posted by AdderMk2
i still dont understand why peope have to ASK what belt is right for the car.
Just maybe because someone has already tried this and knows the answer.
Jfsram is offline
Old 01-30-2010, 09:39 PM
AdderMk2
Banned
AdderMk2's Avatar
so you post, wait 2-4 hours for someone to give you info they THINK is correct, go to the part store, get a belt, and MAYBE get lucky... OR, spend 10 minutes, measure it your damn self, and get the right belt... the first time
hrmm
AdderMk2 is offline
Old 01-30-2010, 11:34 PM
5.0stang.ryan
5.0stang.ryan's Avatar
I have a question about a part of the smog system. I deleted mine a wile back and when i baught the car it wasnt hooked up. They did leave the tube going into the block connected. What does it do and is it hurting me to leave it? I am trying to understand if it would be causing any problems.
5.0stang.ryan is offline
Quick Reply: Smog removal
