Droppin the tranny
Droppin the tranny
Droppin the tranny tomorrow to change out the throw out bearing.
any thing weird i should know before i get too it? any tricks or short cuts?
about how long do you guys think this job should take?
There is a million ways to do it. I've even changed methods a few times myself.
If you don't have a spare yoke to plug the outshaft, dump the transmission fluid before you remove the driveshaft.
I've always removed the shifter from inside the car before removal but I saw something last time I was visiting my friend who has a transmission shop. The lift the boot, undo the two bolts holding the shifter handle to the stubby shifter stick. Then lower the transmssion and pull it out with the shifter still on the transmission. It actually saves many steps in the re/re of a transmission.
It's pretty straight forward but time consuming trying to get to those 4 bolts holding the tranny to the bellhousing. Instead of dropping the tranny completely down I found it easier to just slide it back far enough to get the shaft out of the fork.
If you align the disc with the pilot bearing before you install the transmission. There will be no need to "free" the disc with the pedal.
In this particular situation Stilldyl is just changing a throwout bearing. In this case I'd don't even think about pressing the clutch pedal.
Before you slid the input shaft out. Everything is PERFECTLY aligned. Swap the bearing and reinstall. I guaranty you the disc will be aligned with the pilot bearing if you don't disturb it.
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
