connectors on pedal assembly
I installed my pedal assembly for my manual conversion but I can't find these two connectors and I don't know what this thing does. Can you help me out?
This is the thing, it has two connectors coming out of it.
I only found this on my harness and it plugs into one of them.
I thought that the neutral safety switch was on the other side? That white rod piece that slides? I found those two connectors (one had this loop connector thing clipped into it) and I snapped them into place, one was white, the other black.
No it isn't.
This is the neutral safety switch:
http://www.americanmuscle.com/ford-c...itch-8693.html
The white rod piece that slides is the the neutral safety switch and I have that connected. This is on the other side underneath the quadrant and it has a button that gets pushed down when the clutch would be depressed. Unless you are saying that that is the cruise control?
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
ccdguy
09-19-2015 05:20 PM
