Another stupid question from me :)
new clutches?? mines an automatic... you must realize i am a computer geek, and i have no clue about cars. Please answer questions like i dont know my a$$ hole from a whole in the ground. THANKS
I have changed oil done breaks with help and changed the starter, Beyond that.. thats it
Your rear end has clutches in it......so doesn't your auto transmission for that matter.
http://www.latemodelrestoration.com/...Lok-Clutch-Kit
That is what you need.
The rear indeed has clutches in it unless you go aftermarket.
MAKE SURE, if you try to rebuild the differential carrier(traclok/posi), that you do NOT mix up the bearings/bearing caps. Keep everything the exact same as when you removed it. Otherwise you just f'd yourself.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
