Search
Go Back   MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGaragevBLiveUsed Cars
Search
Sponsored by Weld Racing
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-17-2010, 01:32 PM   #1
NFC94GT
Vehicle: 1994 Mustang GT
Default 1994 PCM Help!
I have a '94 GT with quite a few mods. AFR heads, ported Cobra intake, BBK long-tube headers, Dr Gas X-Pipe, Anderson CAI, 75mm TB, 24# injectors, etc. My older brother owned the car before me and installed a tunable chip in the PCM. He doesn't recall the brand of the chip. Recently, the car won't hold an idle and feels like it is running on 6 cylinders and extremely rich. Had the OBD checked and it trips a 511 code which, of course, is to replace the PCM. My question is - does anyone know if a '94 Cobra PCM will plug directly into a '94 GT? If so, are there any issues with running a Cobra PCM instead of a GT PCM? I would prefer to go after market on the PCM for a fully tunable PCM so I could get the car dyno tuned. Any suggestions for after market PCMs? Thank you for your input!
NFC94GT is offline   Reply With Quote
Old 02-17-2010, 04:09 PM   #2
AdderMk2
Banned
Vehicle: 94 Cobra
Send a message via AIM to AdderMk2
you dont need a new PCM... remove the chip, clean off the contacts and re-install it.
511 code usually pops up when the KAM is disabled in the tune, or is the car is forced to run in open loop
and if you want the car to be "fully tuneable" buy a Moates Quarterhorse
AdderMk2 is offline   Reply With Quote
Old 02-17-2010, 05:54 PM   #3
NFC94GT
Thank you for the reply. I will clean the terminals, reinstall and see what happens. Also, thank you for the suggestion on the tunable PCM. I will let you know what happens.
Old 02-22-2010, 01:20 PM   #4
NFC94GT
AdderMk2,
I disconnected the PCM and chip, cleaned the terminals and reinstalled. I also had the battery disconnected during this time to reset the KAM. I reinstalled all parts and started the car. Same ignition issues. It won't find an idle and sounds like it is running on 6 cylinders. One thing that baffled me was when I checked the plug wires for a miss, I noticed that the even numbered cylinders were firing sporadically. My guess is that the PCM is shot or the unknown after market chip is not sending the correct BIN. Please let me know if you have any other suggestions. Also, do you know if a '94 Cobra PCM will fit the wiring harness of a '94 GT? If so, do you know where I could get a hold of a Cobra PCM?
Thanks!
Old 02-22-2010, 05:14 PM   #5
AdderMk2
Banned
Vehicle: 94 Cobra
again, i highly doubt the PCM is your problem. try removing the chip entirely and running the car again. If it still runs the same way, i would suspect the distributor or TFI module before thinking that the PCM is bad
Old 02-22-2010, 05:36 PM   #6
Bubba 95SN
Vehicle: 1995 Ford Mustang GT
PCM does not make for ignition misfire.
Bubba 95SN is offline   Reply With Quote
MustangForums
Ford Mustang
Paid Advertisement
1994, 1995, 511, 94, 94 gt pcm swap, 95, afr, bad, code, ford, heads, idle, loop, mustang, open, pcm, runs
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails Backup
