burning oil?
burning oil?
every 2000 miles the check engine light comes on. and the oil level is pretty low. its been th same way for the last few times i can remember. theres a lil minimal oil leak but nothin drastic. could it be burning oil? any other causes for it to be that low after only 2000 miles?
What are the codes when the CEL is on?
Its normal to burn some oil but how low is yours? A quart or 2? If so, thats abnormal.
Take alook at the PCV system to make sure thats working correctly. You could also do a compression test of the cylinders as well as a cylinder leakage test to see if you have worn rings ect.
Try a decent synthetic oil like Mobil 1 in a 10W-30 and you may find the oil burning reduced even further, along with improved fuel economy, a cooler engine and better throttle response/more power.
Old dead thread I know but I made an account just to advise against advice given in the last posting in this thread. Using synthetic oil in an '86 engine? Sure, after a rebuild maybe. Otherwise it will just clean up all the dino gunk holding the old seals together and you'd likely find yourself with a lot more burning oil.
lincolnshibuya
12-08-2015 04:37 PM
