front suspension upgrade
you would still probably need the 87 spindles anyway but yes the 04's will allow you to do that. Your wheels will stick out a little farther 94-95 ones are the best. You can also do the 13" cobra uprgrade cheap
When doing the 5 lug you will need the spindle, rotor, caliper and brake line. With the passenger side you will need an adapter to run the newer hose with a fox hard line. If you do use the lincoln rotors your wheel selection will be limited.
09-17-2015 07:32 PM
mungodrums
Suspension
09-07-2015 07:22 PM
