thinking trick flow or gt40p
Old 03-14-2010, 03:57 AM
toms93lx
toms93lx's Avatar
Default thinking trick flow or gt40p
i am thinking about getting trick flow stage one heads and a trickflow stage one cam
question i have what is the differance other than price between trick flow stage one heads and gt40p's
toms93lx is offline
Old 03-14-2010, 05:38 AM
302army187
302army187's Avatar
Ive never heard of trick flow "stage one" heads. odd.
trick flow heads are aluminum, so they are about 20lb's lighter (each) then cast iron heads like the GT40's.
they also have bigger ports which equals MORE power. Have a different valve ange which makes more power, and help's clear the stock pistons, allowing for a bigger cam, which is more power.
trick flow twisted wedge heads are AWESOME for the price. guess how i know.
302army187 is offline
Old 03-14-2010, 08:30 AM
ryppdlm
ryppdlm's Avatar
The best part about going with the trick flow head is that it will be matched to the camshaft that you are going to use. If you go with the GT40's you will need to purchase the correct valve springs to match the cam for optimum performance. I personally would go with the trick flow - good quality and good parts. It is your money and it is your decision.
ryppdlm is offline
Old 03-14-2010, 12:39 PM
toms93lx
toms93lx's Avatar
i know what you mean and was planning on switching out the gt40 heads with the trick flow at the end of summer.....i just dont really want to put the stock heads back on them....if i do put them back on i think i have to get them reworked and that could cost as much as a set of gt40 heads........so so you all know the gt40 is not perminant
toms93lx is offline
Old 03-14-2010, 12:41 PM
toms93lx
toms93lx's Avatar
Trick Flow Specialties TFS-51402000 - Trick Flow® Track Max® Hydraulic Roller Camshafts for Ford 5.0L
Camshaft, Track Max, Hydraulic Roller Tappet, Advertised Duration 283/291,Lift .499/.510, Ford, 5.0, 5.8L
Trick Flow Specialties TFS-51400004 - Trick Flow® Twisted Wedge® 170 Cylinder Heads for Small Block Ford
Cylinder Heads, Twisted Wedge® 170, Fast As Cast, Aluminum, Assembled, 61cc Chamber, Ford, Small Block, Pair
this is the set i mean some part stores call it stage ones
toms93lx is offline
Old 03-14-2010, 12:50 PM
jssblues
jssblues's Avatar
so how do you go about choosing the right springs, i have gt40p heads and stage 1 cam and i know i need to upgrade springs
jssblues is offline
Old 03-14-2010, 12:57 PM
toms93lx
toms93lx's Avatar
the people at trick flow said that with TFS-51402000 cam that i wouldnt have to change the springs but if so springs are easy to put on and i am sure summit or trick flow can find the right springs to put on the heads but like i said trick flow said that the cam will work with the stock heads ill call them monday and see what they say about the gt40 head springs
toms93lx is offline
Old 03-14-2010, 01:26 PM
93hatch306
93hatch306's Avatar
don't bother with the GT-40's. if you can afford Trick Flows, get 'em...I'm glad I did.
93hatch306 is offline
Old 03-14-2010, 03:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
trick flow and don't look back.................springs are chosen based on cam selected
mjr46 is offline
Old 03-14-2010, 04:13 PM
jssblues
jssblues's Avatar
so what springs would you recomend for gt40p with tfs-1 cam
jssblues is offline
Quick Reply: thinking trick flow or gt40p
