1988 Mustang Mass Air Conversion Using 89 harness no spark or fuel pump. need HELP
Old 03-28-2010, 02:32 AM
tara0321
tara0321's Avatar
Default 1988 Mustang Mass Air Conversion Using 89 harness no spark or fuel pump. need HELP
trying to convert my 88 from speed to mass air. used an 89 harness but have no fuel pump or spark. need help
tara0321 is offline
Old 03-28-2010, 06:51 AM
AdderMk2
Banned
AdderMk2's Avatar
more details
AdderMk2 is offline
Old 03-28-2010, 07:33 AM
jssblues
jssblues's Avatar
you know that you cant just swap computers, there is a little bit of re-wiring you have to do..
this may help http://www.corral.net/tech/powerplant/maf_tech_2.html
jssblues is offline
Old 03-28-2010, 12:28 PM
tara0321
tara0321's Avatar
read that with the 89 computer harness u could just plug it in an your ready to go. so i got the 89 harness and plug it in an got no fuel or spark. i have a a9l computer,24# inj, 70mm MAF, holley systemax kit, accel distributor and ignition
tara0321 is offline
Old 03-28-2010, 12:43 PM
tara0321
tara0321's Avatar
atleast i was told it was an 89 harness. Has the single green connector by the computer an eec relay then it has the MAF connector and a relay out by the MAF connector.
tara0321 is offline
Old 03-28-2010, 10:59 PM
Locosway
Locosway's Avatar
With the 89 harness it is plug n play. You also need the MAF and the computer. Since you have the A9L and everything you should be good to go.
Did you hook the ground back up when you switched the ECU?
What codes is the computer throwing?
Locosway is offline
Old 03-28-2010, 11:34 PM
tara0321
tara0321's Avatar
ground by computer good. dnt know what codes there but coil has 12v, no voltage to TPS on orange wire, an only 3 volts on red wire to injectors. also cant get wipers to shut off.
tara0321 is offline
Old 03-29-2010, 03:13 PM
tara0321
tara0321's Avatar
eec relay has red wire and orange wire with black tracer 4V, Red wire with green tracer 12V, Black wire with Green tracer OHM-12, 2 Black wires with orange tracer nothing
tara0321 is offline
Old 03-29-2010, 11:30 PM
pony831
pony831's Avatar
When i converted my 87gt to mass air, i used a 88 mass air harness....all i did was tap my fuel pump to my ignition switch and splice the pink/black wire of the fuel pump relay(under the drivers seat) into pin #19 on the ecu
pony831 is offline
Old 03-30-2010, 07:23 AM
liljoe07
liljoe07's Avatar
Its a fuse link issue more than likely. Black orange wire should be a constant 12v key on or off.
liljoe07 is offline
Quick Reply: 1988 Mustang Mass Air Conversion Using 89 harness no spark or fuel pump. need HELP
