95 5.0 budget smog delete.
Old 03-30-2010, 07:00 PM
txjason1
txjason1's Avatar
Default 95 5.0 budget smog delete.
Anyone that has already done the poor mans smog pump delete, in a 94 or 95 mustang GT/GTS, please supply the belt part number that worked for you.
Please only respond if you left your AC intact, and removed smog.
I have tried 2 different belts, neither works.
Thanks a million.
Jason
txjason1 is offline
Old 03-30-2010, 10:03 PM
minnow81469
minnow81469's Avatar
lol blue oval industries makes a pulley for smog delete 60 bucks then if you got the stock heads plug the back of the heads easy stuff man uses the stock size belt
minnow81469 is offline
Old 03-30-2010, 10:41 PM
txjason1
txjason1's Avatar
thanks minnow,
but if I wanted to spend $60.00 for smog pump delete, versus $20.00 for a belt.
I have 5 kids, and am extremely low Soldiers budget. Thanks tho!
I still need the belt number guys...already rerouted, but belt sizing is a problem.
Thankzzzzzzzzzzzzzzzzzz!
txjason1 is offline
Old 03-31-2010, 08:30 AM
mxrider426
mxrider426's Avatar
Take a piece of string and wrap it around all your pulleys as the belt would be. Measure the string and then go buy a belt that length
mxrider426 is offline
Old 03-31-2010, 08:53 AM
Tony71502
Tony71502's Avatar
Put your belt back on, drive to the parts store, and test out belt sizes until you find the one you need.
Tony71502 is offline
Old 03-31-2010, 09:11 AM
luckythirteen13
luckythirteen13's Avatar
+1, but dont use string, use a piece of wire. string stretches when you pull on it.
your being lazy, you dont need a part number just measure it
luckythirteen13 is offline
mrtrodonet
09-19-2020 03:12 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Teddi
09-29-2015 12:24 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 95 5.0 budget smog delete.
