heads and cam - MustangForums.com
Old 04-05-2010, 01:16 PM   #1
hotstang97gt
Default heads and cam
im going to be putting a new heads and cam in my car. i have trick flow heads for it but im not exactly sure on what kind of cam to get. i want a good street/strip cam. the engines stock, its got a 650 carb. hearders are stock at the moment but long tubes are going to replace them. i have 1.7 roller rockers from a previous car. id like to use them if possible. how do you know what size push rods to use?
hotstang97gt is offline   Reply With Quote
Old 04-05-2010, 04:30 PM   #2
02WhiteGTVert
02WhiteGTVert's Avatar
02WhiteGTVert is offline   Reply With Quote
Old 04-05-2010, 07:54 PM   #3
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Yup, measure for them is the only correct way.
mjr46 is offline   Reply With Quote
Old 04-05-2010, 08:25 PM   #4
minnow81469
what cam are you going with?
minnow81469 is offline   Reply With Quote
Old 04-05-2010, 09:32 PM   #5
hotstang97gt
im not sure. i was hoping you guys would have some good suggestions. i heard comp cams are good to go with, but im not sure on what one to get. what would you guys suggest?
Old 04-06-2010, 06:11 PM   #6
hotstang97gt
anyone have suggestion on which cam i should get? i dont really know too much about them
Old 04-06-2010, 06:41 PM   #7
minnow81469
call comp cams and talk to them about what you got thats the best way there number is 1-800-999-0853 i couldnt even give u guess
Old 04-06-2010, 11:12 PM   #8
dflo209
dflo209's Avatar
Either go with a stage two cam from trick flow or a F303 either one is a good cam....
dflo209 is offline   Reply With Quote
Old 04-07-2010, 07:25 PM   #9
minnow81469
dont get the f303 cam letter cams are garbage id call comp they will hook you up and you wont be disappointed
Old 04-07-2010, 08:31 PM   #10
mjr46
mjr46's Avatar
personally, I'd call someone who specializes in cams that does alot of mustang specific grinds, such as www.flowtechinduction.com or www.camshaftinnovations.com
extnesion for radio antenna to head unit kevsgt 2005-2014 Mustangs 5 10-09-2015 11:12 PM
Any tuner available 95 3.8 ?? patchshaffer Tuner Central 3 10-05-2015 03:24 PM
So who wins uedlose The Racers Bench 4 10-01-2015 09:31 PM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 10:01 AM
cost to rebuild heads Drastang 4.6L (1996-2004 Modular) Mustang 2 09-30-2015 04:48 AM
2031, cam, carburetor, crane, kit
