i drove around with the fuel gage hooked up and taped to my window for 2 days and finally got the problem to happen while the gage was hooked up . the fuel psi had no change , so its got to be somethin else. i'm gonna goahead and change the TFI mod. and the pickup coil and see how that works but, i can't get the pickup plate to come off or pull out, it only pulls up about 2mm thats it....
gotta pull the distributor out, bang the roll pin out of the cam gear, and the whole thing slides up.
i'd run codes first tho, just incase.
i changed the whole distri. assy. including the tfi mod. and pickup coil and rechecked the timing , still no fix. maybe gonna try changing the map sensor.... unless any other ideas.
