okay im thinkin about removin my quad shock to fit wider tires and if i do will this affect handling and perfromance? whats the widest trie that will fit if i remove the quad shock assembly? thanks
you can try in fliping them over to gain about an inch and they still work...if you install a aftermarket set of upper and lower control arms thier not needed anyway
No not unless you get a good aftermarket set of U/L control arms,since the quads help control wheel hop and aftermarket control arms will virtualy eliminate the need for the quad shocks
If you have decent upper and lower control arms they aren't needed. I pulled mine to accommodate 275/50/15's with 15X8 Weld's and have no wheel hop at all. I did need to add 1/2" spacers to keep the tires off the inside well.
