Smog Pump Removal
Old 04-22-2010, 09:41 AM
srileyinc
srileyinc's Avatar
Default Smog Pump Removal
I just recieved a dummy pully in the mail to remove my smog pump. Question is besides replacing the pump with pully removing the hoses, what else is involved. do you need to plug anything up. I cant see where the hose go to behind the engine. Any info on this would be great....car is a 92 GT 5.0......THanks
srileyinc is offline
Old 04-22-2010, 09:43 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
either remove the tube that bolts to the back of the heads and plug with a 5/8- 11 bolt 3/4 long iirc and cap off any vaccum hoses
mjr46 is offline
Old 04-22-2010, 10:12 AM
luckythirteen13
luckythirteen13's Avatar
why did you buy an idler pulley when you could have just bought a smaller belt?
luckythirteen13 is offline
Old 04-22-2010, 10:27 AM
srileyinc
srileyinc's Avatar
lucky13 good question. since I already have it i guess ill use it. didnt know you could do that..
Old 04-22-2010, 12:40 PM
luckythirteen13
if you can return it, i would. get some money back. having nothing there will clean up the engine bay.
Old 04-26-2010, 09:11 AM
srileyinc
srileyinc's Avatar
"either remove the tube that bolts to the back of the heads and plug with a 5/8- 11 bolt 3/4 long iirc and cap off any vaccum hoses"
WHat do you mean by "iirc"....
Old 04-26-2010, 09:20 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
IIRC=if i remember correctly
the belt you use without a pulley is a 770k6 to eliminate the smog pump
rmodel65 is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Smog Pump Removal
