HELP NO SPARK
HELP NO SPARK
Hi My Mustang has no spark right off the coil parts that have been replaced are a new ignition control module new coil and about 4 months ago when this last happened I replaced the hole distributor and it ran great but now its happening again
All fuses check out okay
there is power to both wires going to the coil but not sure if thats normal
the next thing I can think of would be the computer ?
if you know anything that can help me I would appreciate it
Its a 1994 5.0 5 speed
the module is new, on my car it was mounted under the airbox on the passenger side fender and it was running and then died out and then i checked for fuel pressure since i just put in a fuel pump but that was good and then i put on my spark tester and am getting nothing right off the coil but power to both sides of the coil.
that is considering that all your fuses are good that is....
