Distributor advance mechanism?
I'm in the process of ordering parts for my 331 build this summer, and I'm confused as to what I need in terms of a new distributor - I'm building a 331 stroker with a hydraulic roller cam block, and a stock mass air computer. I'm planning to get a super pro bullet block from DSS Racing.
I've got Trick Flow Twisted Wedge heads, and a Trick Flow Track Max cam to go with it - now I'm trying to figure out:
a) what kind of gear material i need on the distributor
b) what advance mechanism i need from the following:
- mechanical
- electronic
- vacuum and electronic
- vacuum and mechanical
I have no idea what kind of hookup I need for each of these, so I'm wondering what the stock setup is, as I'll probably be close to this. It looks like all the other parts I'll be using will be from 89-91 factory parts, which is what I got in the box-o-parts when I bought this car.
- mechanical
- electronic
i was looking at mallory distributors... are you suggesting that an aftermarket distributor is overkill? or would this mean that i would want an electronic advance mallory distributor (i'm assuming the computer then controls the advance)?
so i was thinking in terms of precision of the rotor - it seems to me that a higher quality dizzy would have a more precise control over timing. nothing too extreme, probably on the order of milliseconds, but it seems to me that milliseconds can make a critical difference in placing the spark at the exact correct moment in the stroke cycle.
an efi distributor does not move like the old vac or cintrifical weighted dizzys...
ure computer/ignition module are the brains, the PIP picks up the crank position and reports to the computer. ure dizzy is a dumb device it jus fires when told to... wether its retarded or advanced based on the conditions the computer sees.
i think i'll spring the extra $150 or so and get a nice mallory dizzy like i was planning to - comes with an ignition module IIRC.
from what i gather here i'm looking for an electrical advance dizzy since my car is efi and has an ecm.
