Lost ALL power!!! Help!!!
Old 05-21-2010, 12:27 PM
HAUS
HAUS's Avatar
Originally Posted by Prof_Snakes
Ran the tests again and the SEFI codes went away
cleared the memory and ran tests again. got no KOEO codes and the same KOER codes.
So on the KOEO test you got 111??
173 is a KOER code so are you sure you got that code on the engine off test?
as far as the 311 and 314 go. Do you have your smog pump hooked up?
HAUS is offline
Old 05-22-2010, 11:35 AM
Prof_Snakes
Prof_Snakes's Avatar
Yes after I cleared the memory I got 111 on the KOEO test.
I believe that when I got 173 on the KOEO test it was as a stored code.
And the SMOG pump is hooked up.
Unfortunately I just got My old job back and won't have time to work on it myself anymore. Work is 7 days a week 12 hours a day. Ended up dropping it off at the shop. Waiting to see what they come up with now.
Prof_Snakes is offline
jrrhd73must
10-02-2015 09:17 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: Lost ALL power!!! Help!!!
