First Mods to 5.0's
RE: First Mods to 5.0's
ORIGINAL: razarr69
stanglx2002 how do u delete the coolant lines to the EGR spacer, block off the EGR valve?
you can leave the vacuum line to the EGR and still bypass the coolant lines, i didnt plug the lines, i got a piece of 1/4" steel brake line 6" long and hooked them together, no need to plug the coolant passages into the spacer afterwards either. also, deleting the crankcase vent tube can cause positive crankcase pressure which causes loss of power, and oil leaks to name a few things. even with the breather type oil caps the pressure is higher. the tube that goes to the intake actually draws the pressure from the crankase helping to make power, and unless you remove the baffle inside the valve covers oil wont get sucked sucked into the intake by this tube, oil vapor will, which is good for upper cylinder and combustion chamber lubing.
Matt's 95 Stang
10-05-2015 07:16 AM
